4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
Anyone ever tried using hockey pucks instead of wood blocks when mounting the bed? Pucks will outlast wood and there might be a little bit of give in them to make the ride a bit softer. I know that a lot of guys use them to jack their 4WD trucks up,
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I used pucks in my 50 chevy and it worked just great.
cheap and long lasting
Jim
Good luck with your project!
Jim
Don't do it. The pucks will fail on you.
No one uses them on 4x4's anymore because they can't take the abuse.
Use poly bushings from companies like Daystar, Prothane, MORE or original rubber bushings but not pucks.
It just ain't right.
PS: If you own a 63-72 pickup then check this out:
http://www.tellico4x4.com/index.php/cPath/419_3007?osCsid=a94c2787259caf3006abc17247315c9e
also if you are caught by the highway patrols doin a inspection you will get a very heavy fine for using none approved mount materials they will have a field day with you and the pucks
Some interesting answers. I have decided to use the rubber pads. As far as highway patrol is concerned, we don't have to worry much about being stopped for a mechanical inspection. Half the vehicles up here have a burned headlight and have driven that way for years. No one even looks. Sad!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Pucks should only be put in the net
