4 members (KEVINSKI, RaNfLaS, moparguy, 1 invisible), 102 guests, and 2 robots.
Topics128,094
Posts1,056,060
Members48,433
#325096 01/24/2006 4:15 AM
Junior Member
Junior Member
today i finished sanding and sandblasting my pickup box got rust and some pretty good size holes where the wheel house boxes bolt to the inside of the box i've tried to gauge the metal for thickness i cant tell what it is if'ts 18 or 20 gauge i got one of each just in case at the metal shop thanks !
#325097 01/24/2006 1:42 PM
omaha, I have a '50 1/2 ton and need to replace some steel on the bed side panels. I measured mine yesterday at 0.065" thickness. I believe this is 14 or 16 gauge steel. But I could be wrong. I'm sure someone else will chime in more definitively.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#325098 01/24/2006 3:24 PM
omaha joe,
If I remember correctly, this was talked about this in an earlier post. I think the general consensus was 19 gauge, which is about .054.
Stuart
#325099 01/24/2006 8:28 PM
Hey Joe,... Look at Mar-K. From all indications, it looks like the front and sides are 16ga and the cross sills are 14ga.
1941 AK named "PETEY" my buddy.
#325100 02/05/2006 5:12 AM
Quote
Sorry it took a while to get to this one, it slipped by me. You are correct, the front panels, bed sides and tailgates we make are 16 gage (.056") and the cross sills and rear sills are 14 gage (.072"). These thickess measurements are toward the bottom of the range for each gage and that is pretty common with steel suppliers today. With old sheet metal, 40's and 50's vintage, they often were a little thicker, so the .065 measurement is probably 16 gage. You would have a hard time finding .065" thickness steel sheet today unless you special ordered it from the mill.
Mar-Ktech
