4 members (tclederman, Gray_Ghost, Otto Skorzeny, 1 invisible), 100 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
#3222 07/30/2003 2:19 AM
jf
Offline
I just replaced the rubber hose the PO had running from the fuel pump up to the carb. I purchased it from the Paddock (the believe the part was made by inline tube?) and had to use a 2 inch rubber section and a little bending to connect it to the pump. Now the line is in contact with the water neck. Is that where it is supposed to be... if not will that cause any problems because I am pretty sure that it is heating the fuel.
thanks
jf
#3223 07/30/2003 2:36 AM
Is this a rubber hose all the way from the fuel pump to the carb? mine has a metal line up most of the way and then parital rubber hose, I don't guess it would hurt anything but I would not want it rubbing against anything,can you re-route it or make it longer,,,just a thought...Fred
Redryder pix
My Hotrod
#3224 07/30/2003 3:08 AM
jf
Offline
The PO used a full rubber line. The replacement I purchased is metal.
jf
#3225 07/30/2003 5:26 AM
most of the 6's have a metal fuel line that runs right between the valve cover and the thermostat housing - the 235 has a clip to hold it from vibrating, but that clip is held by the housing bolt - don't think under normal conditions it's a problem
#3226 07/30/2003 5:34 PM
If it bothers you, slit a rubber hose lengthwise and slip it over the metal line to insulate it from the water neck. If it wants to slide around use some hose clamps on it.
Paint & Body Shop moderator
#3227 07/30/2003 8:05 PM
Here are two photos showing the routing. The vacuum line is clipped to it, and there is a bolt hole in the thermostat housing for the clamp.
right side
left side
Fred
52 3600
69 C-10
#3228 07/30/2003 9:56 PM
Hello FredT how do you post pictures on this board Thanks biddaboy
1956 GMC TF 1/2 ton
1955 GMC 500 model (Gumby)
#3229 07/30/2003 10:24 PM
Hey, Fred T
Why do you use such a LARGE air cleaner?? wink
PRW
#3230 07/31/2003 3:39 PM
To post pictures you have to have somewhere to hang them up, there are some free hosts that will let you use their space. Others know more about it than I, and a search of the lounge will tell you how.
That little air cleaner came at the right price, and didn't require an adapter. I know have a larger cleaner with an adapter that was machined from aluminum tube and is a tight fit on the carb.
Fred
52 3600
69 C-10
