| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31846 03/19/2005 5:17 PM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hey Bolters, I got a buddy who says I can have a compleate 86 Firebird free if I haual away.I still havent got a rear end for my 53'3100 as I am burried deep in patch panels repairing cab.Would this bird rearend be a good transplant with a saginaw 4speed and a 235? If so are the disk brake setup on the bird the same ones that the popular conversision kits use roters-calipers-ect,from Thanks Aaron | | |
#31847 03/19/2005 5:24 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I have used an 84 trans am rear in a 54 1/2 ton. Worked great. Measure from hub to hub. If it's between 61 and 62 inches, your good to go. I don't know about the front end though, but I'm sure someone else will chime in soon. Good luck. Also check milage on the bird. May need more work than it's worth. (wheel bearings, seals, gears, etc...) | | |
#31848 03/19/2005 10:05 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The disk kit I used required mid-size parts like from a Chevelle, but other kits I've seen used Camaro parts, so the Firebird will probably work just fine.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#31849 03/21/2005 4:44 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | So if I use the rearend outa the bird and the brake parts off the bird wont work-and I get the right stuff off a midsize G M will my lugnut pattern be same on front and rear? thanks Aaron | | |
