2 members (RoadsScholar, 1 invisible), 154 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#31846 03/19/2005 5:17 PM
Hey Bolters,
I got a buddy who says I can have a compleate 86 Firebird free if I haual away.I still havent got a rear end for my 53'3100 as I am burried deep in patch panels repairing cab.Would this bird rearend be a good transplant with a saginaw 4speed and a 235? If so are the disk brake setup on the bird the same ones that the popular conversision kits use roters-calipers-ect,from Thanks Aaron
#31847 03/19/2005 5:24 PM
I have used an 84 trans am rear in a 54 1/2 ton. Worked great. Measure from hub to hub. If it's between 61 and 62 inches, your good to go. I don't know about the front end though, but I'm sure someone else will chime in soon. Good luck. Also check milage on the bird. May need more work than it's worth. (wheel bearings, seals, gears, etc...)
#31848 03/19/2005 10:05 PM
The disk kit I used required mid-size parts like from a Chevelle, but other kits I've seen used Camaro parts, so the Firebird will probably work just fine.
#31849 03/21/2005 4:44 AM
So if I use the rearend outa the bird and the brake parts off the bird wont work-and I get the right stuff off a midsize G M will my lugnut pattern be same on front and rear? thanks Aaron
