1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31792 10/17/2005 12:34 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have been trying to find a good used round heater core with no luck yet. Rather than running two heater hoses with a clamp on the ends I thought about just putting pipe plugs in the water pump where the outle/inlet holes are. Any suggestions? Bill | | |
#31793 10/17/2005 12:59 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Pipe plugs will work fine.
Gonna get cold up there this winter? | | |
#31794 10/17/2005 3:37 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | We always took one hose and routed it as a bypass. When I was young, I was taught that these engines needed the heater as a cooling system bypass that was needed to keep tht coolant flowing through the engine when the thermostat is shut. I don't know if that is true or not, but have continued the practice.
Fred 52 3600 69 C-10
#31795 10/17/2005 6:36 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Considering that it was fairly common for trucks to be bought without heaters, I don't think blocking the connection holes is a problem. | | |
#31796 10/17/2005 9:19 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It matters if you have a 261 and are running it with a 235 non-bypass thermostat, but for a 216 or 235 it doesn't matter.
#31797 10/17/2005 12:48 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | 4onthefloor, Why is the 261 different? How do you know if you have a 235 non-bypass thermostat? I have not put my rebuilt 261 back in my truck yet, but I installed a brass water shutoff valve in the heater hose outlet on my water pump, so I could shut off the flow to the heater during the summer. Will this be a problem? Here is a pic of the engine w/ the shut off valve installed: http://community.webshots.com/photo/109150147/120822879MhXjeY
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#31798 10/17/2005 2:50 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | oldblu49,
I am not sure what year your rig is, but the old heater cores were made of pretty tought stuff. Isn't there a radiator repair shop near you that could repair your core. If this isn't they way you intend to go, it might be fun to try and repair it yourself...if you fail, nothing lost.
Stuart. | | |
#31799 10/17/2005 9:36 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Stuart, Its a 49 Harriso heater. I have three of these round cores and two rad shops have given up on repairing or makng one good one out of the three. At the moment they are in a third rad shop awaiting inspection. And for tclederman, naw it won't get too cold up here. We are on the west coast and it seldom goes below freezing. One of Canada's hidden surprises! | | |
#31800 10/17/2005 10:46 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 261 is differant because of the siamesed cylinders and the steam holes in the head. It needs water flow through the head to avoid steam problems and head cracking, especially while the engine is warming up. The bypass thermostat has a basket type thermostat that sends water back to the water pump when closed, allowing circulation. It has a larger housing than the standard 235 type. You need a heater or a bypass hose if you are not using the big truck 261 thermostat housing.
#31801 10/17/2005 10:53 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Cujo8 - This is from an article in the tech tips section of inliners international. "In pure big truck form the 261 has a larger thermostat housing holding a double acting thermostat. This is designed to circulate water through the block and head before the thermostat opens to allow hot water into the radiator. Thus, no internal steam hot spots during warm ups, especially in winter. This is particularly important with very cold coolant. Vital engine spots can become very hot before the total coolant becomes hot enough to open a normal thermostat on the front of the block." You can tell it's a thermo housing from a 261 if it has 2 holes drilled for the smaller hose fittings in addition to the large one that feeds from the radiator. It is slightly larger than the 235 housing and it contains a hard to find by-pass thermostat. 4onthefloor turned me on to this for waterheating my intake and I couldn't be more pleased with the results. Thanks again! | | |
#31802 10/17/2005 11:50 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | A couple of other problems arise - finding that "hard to find thermostat" and the hose size change from the radiator to the housing. Any suggestions on where to find wither? Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#31803 10/17/2005 11:53 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | One must always "Preview Post" to be sure the spelling is correct, mustn't one! It should be: "Any suggestions on where to find either?" :confused: Joe
#31804 10/18/2005 12:06 AM | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | hey Joe did you go to Oklahoma to the swap meet?.........Ronnie | | |
#31805 10/18/2005 2:31 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Joe, the radiator hose fits my 261 housing as it did my old 235 housing. Being a 62, maybe it was different than what you've seen. I found the by-pass thermostat at a local parts plus. You have to get them to look in the industrial truck catalog. It helps if you have an old one to compare it to. Be aware, you must take measurements since the replacement doesn't exactly look the same. | | |
#31806 10/18/2005 5:42 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yes, Ronnie, I was up there Friday from about 10:00 am until about 3:00 pm. They had a full house except for the new area they have added on the far side of the grounds. A pretty good crowd, but not as much as last year on Friday. I didn't see much Chevy truck stuff - one guy had an old dirty Offenhauser intake with two Rochesters on it, an old dirty Offenhauser valve cover and a home made split manifold that looked ok for $550.00. I stood there and looked at it for a few minuets trying to figure out how come it was supposed to be worth that much, walked away an bought some peanuts. Got a good deal on the peanuts! The burger I had for lunch in the indoor arena lunch room was good! I've been to Chickasha every year since 1985. This was not a memorable year. Joe
#31807 10/18/2005 5:51 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | doc - I've been running a 235 thermostat housing and thermostat on my 261 for about 12 years. I thought the 261 housing took a larger hose, but you are probably right about it being the same size - it almost has to be to since all of the radiator necks were the same size. I sure would like to see a picture - if any body has one - of that thermostat. I probably should be running that on my 261 for things to be totally right. Anybody got a picture from a box or have an old one you can take a shot of? Thanks for the help and oldblu49, I didn't mean to hi-jack your post. It just got too interesting for me to pass up!!  Hope it was OK! I'll shut up now! Joe
#31808 10/18/2005 12:53 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Doctasuds or 4onthefloor, Can you tell from the picture I linked to above if I have the 235 or 261 thermostat housing? I also would be intertested in seeing a picture of the bypass thermostat you guys mentioned. Would drilling a few 1/8" holes in the thermostat help with this issue?
#31809 10/18/2005 4:40 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | cujo8 - Here are some pics of my set-up. I think I may have some solo pics of just the thermo housing, but I have to find them first! http://community.webshots.com/user/doctasuds It appears that you have a 261 waterpump. That thermohousing is hard to see, but it looks like it's from a 235. | | |
#31810 10/19/2005 8:06 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Cujo, You definately have the right water pump, just replace the extra pipe plug in the water pump with a nipple and run the hose from it to the "bypass" outlet of the thermostat housing. The picture is from the wrong angle for me to see the thermostat housing very well.
I think the thermostat for the bypass housing is Stant #13928 but please verify that before you install. I can't remember which hose nipple on the housing is the bypass. It should be the one that is blocked by the thermostat when it opens.
The thermostat from a bypass setup looks kind of like a sink strainer. It actually works like a switch rather than a block. It routes water to the bypass hose when cold and to the radiator when warm, and it blocks the bypass but not the heater when open.
#31811 10/19/2005 11:53 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | There is a '58 Viking 60 for sale on ebay in commercial trucks item #4583211573. That is definately a 261 waterpump and thermo housing. The guy thinks it is a 235. I would bet that it is a 261. | | |
#31812 10/20/2005 12:37 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That truck also has the factory PCV system on it, also scarce. It looks like the heater is hooked up wrong, I bet it only works when the thermostat is closed.
If anyone on this board buys that truck I would like the PCV system off of it.
#31813 10/20/2005 2:13 AM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | On my 261 I could not find a basket type thermostat, and after looking at the housing closer, I found a crack so I did not use it.
I called Jim Carter and told him what I needed. He sent me a housing similar to a 235. Check out my webshots page below and see if I need to make any adjustments. This motor runs extremely well and has 250-300 miles on it to date.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
#31814 10/20/2005 2:47 AM | Joined: Apr 2003 Posts: 22 New Guy | | New Guy Joined: Apr 2003 Posts: 22 | Originally posted by 4ontheFloor: Cujo, You definately have the right water pump, just replace the extra pipe plug in the water pump with a nipple and run the hose from it to the "bypass" outlet of the thermostat housing. I have a Langdon's thermostat housing spacer w/ a threaded water outlet installed on my 261 engine and I am going to use that outlet along with the one that is currently plugged on the water pump to heat my Offy 2x1 intake manifold. I am thinking that this will act as a "bypass" setup as long as I get the proper bypass thermostat installed. I think I must have a 235 thermostat housing, since it only has one threaded heater hose outlet in it, so if I was to hook up a bypass-hose from the 2nd heater hose connection on the water pump to the heater hose connection on the thermostat housing, I would then not have anywhere to hook up my return line from my heater. Clear as mud :confused: .
Jim
#31815 10/20/2005 2:51 AM | Joined: Apr 2003 Posts: 22 New Guy | | New Guy Joined: Apr 2003 Posts: 22 | If I indeed have a 235 thermostat housing on my 261, can I still install a bypass thermostat in it? or won't it fit in a 235 housing?
Jim
#31816 10/20/2005 3:29 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | The 261 by-pass thermostat will definately not fit in your 235 housing. It seals in 2 places as opposed to one and comes with a separate interior gasket. I don't know if you need one or not. Hey 4onthefloor, I noticed that heater hook up as well. I don't think the circulation will work very well without the pump - maybe it will? I wish I lived closer to that guy. I would buy it for the motor. | | |
#31817 10/20/2005 12:40 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | After thinking about this further, I don't think I will need the bypass thermostat, since with the Langdon thermostat spacer setup for my Offy intake will act as a thermostat bypass.
