5 members (MikeStone1953, Hawkman, fonz8261, 55shaker, Gdads51), 143 guests, and 3 robots.
Topics128,086
Posts1,056,099
Members48,434
#31399 05/12/2003 10:16 PM
Junior Member
Junior Member
I recently purchased a 1986 Chev 1/2 ton for a donor for my '61 Chev apache. My fram eon the '60 is in rough shape and I am swapping out the front suspension for sure.. Have any of you guys ever shortened an 80's frame to sit under the 60 body??? I have two options either work with the 86 frame entirely or clip the 60 frame with the 80's front suspension and rear axle. Any suggestions would be great I couldn't pass up the '86 the body is shot but it has a tilt column power brakes a running 305 and a good rear end all for $250
#31400 05/13/2003 1:13 AM
take it. i have recently gone the other way with my 61 3/4 ton and am now a bit regretful. all the stock pieces i had to source out locally because it is a 3/4, and at quite a cost. the front x-member will bolt in with few modifications (ie elongating bolt holes...big deal) and you get the benefits of pwr steering/brakes, a dual circuit master cylinder in case of emergencies, and a small block will fit right in with motor mounts, as it doesn't sound like you're restoring. you can also rebuild all the bushings etc from the donor for a fraction of the cost. The only problem i had was finding rear control arms as they are very xpensive and i built my own.where abouts are you in canada?
1961 Chev 3/4
1977 Chev Nova
#31401 05/13/2003 4:00 AM
Sounds like you are living my dreams. Its not hard to shorten a frame. Just make sure you measure twice, cut once. The best way is to cut it half way down, then lenght wise, then the rest of the way down making a sort of lazy "Z". That way when you reweld it you make it stronger than a straight cut. If you plan to do all the swapping I'd go with the 86 frame and graft on the 60's body. That way you have the modern goodies underneath.
1965 Chevy C-10 Longbed Stepside
#31402 05/23/2003 2:23 AM
Junior Member
Junior Member
Thanks alot guys.. I have recently stripped the 85 truck.. there is a bit of rot in the frame but its right behind the cab right where I have to shorten it so its not that bad.. I have to make the wheelbase 115" to fit the 60 body.. the frame on the 85 is nice a striaght behind the cab should be pretty straight foward,, any more advice would be greatly appreciated ..
Thanks again
