| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | Hope this is the correct forum for this, I'm new to this board. I am putting headers on the 250 in my 70 Chevy. I am replacing the bolts with studs to hold the manifold/headers on. My question is the two "alignment studs (guess that is what they are called)", do I need to take them out and replace them with a stud/bolt now that I have headers going on?
This truck is my first project in a while so I am rusty on this stuff. If it is recommended that I replace them with a stud, do they just twist out. BTW engin is still in the truck.
Bill | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I recommend replacing them with the short bolts that should come as part of your header kit, if you're buying the headers new.
A stud would work fine too. But the ends are easy to reach and tighten/loosen as needed. No need to do a stud just for better clamping on the ends, in my opinion.
-ftyler | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The alignment pins are screwed in. Hit them with some penetrating oil a few times and allow them to soak for a day or so, then get out the vise-grips. If you have to use heat you will need to heat the head around the pin. Make a note that if you ever do this again to remove the exhaust manifold when the engine is hot, the bolts come out easier.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Mine came right, but had coolant behind them. I ended up with studs and thread sealer. I tryed headed bolts but they keep leaking coolant. Joe | | | | | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Palf: Thanks for posting this question. I'll be doing this conversion myself this summer, and I wouldn't have thought of that until I was in it.
35 + years of rollin' steel!
| | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | Thanks guys. Hopefully I'll get to swap them out soon. Just getting ready to start on a new workshop so, mods to the 70 will be on hold a short while, but I wanted to be ready when I get the time to get back on it.
Thanks again.
Bill | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Get the motor good and hot after a hard day's driving. Take a block of parrafin canning wax and touch each of the bolts, studs, you want to take out. It will melt and suck right in. When you want them out they will come out easy.  | | |
