Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (KingG, Joe H, Lightholder's Dad), 42 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#30716 05/09/2005 5:10 PM
Junior Member
Junior Member
I hope someone out there can help me.
I have a '51 3/4 ton with a 235 engine. A few days ago I got the strong smell of gasoline while driving and the engine stalled when it idled(something it's never done before). When I got home I opened the hood and saw gas spewing out of the carburator. A couple of days later, and I don't seem to be getting any gas at all. If I pour gas directly into the carb, it starts right up and will run fine (for over half an hour with no gas spewing out of the carb anymore). But when I shut it down and try to start it again, it seems to be starved for gas again. The fuel bowl shows that there is gas in the line.
Any ideas?
#30717 05/09/2005 5:35 PM
8
8 Offline
Sounds like typical Rochester carb problems. Have you rebuilt it lately? Even if you have, check it out.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#30718 05/09/2005 5:45 PM
Junior Member
Junior Member
Thanks fab51. I guess there's no getting around it. The carb needs a rebuild.
#30719 05/10/2005 1:25 PM
I'm having the same problem with the float sticking on my Rochester B causing the carburetor to overflow. I tried a different float. I made certain it was adjusted to 1-9/32" and 1-3/4". It is not hitting the sides of the carburetor. I cannot find anything that would be causing it to stick. And the float doesn't have a hole in it either. I've tried two different floats with no success. The problem is intermittent. You never know when its going to happen. Any ideas????
Rob Mathis
48 Half Ton with 235 & SM420
#30720 05/10/2005 2:37 PM
I had similar problems with my Rochesters...Carbs loading up...we installed an adjustable fuel pressure valve (NAPA) and reduced fuel pressure to 4-5 lbs. Stopped the problem and was relatively inexpensive.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#30721 05/12/2005 7:14 PM
It appears my problem was some trash in the needle valve preventing it from closing.
Rob Mathis
