0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#30252 11/10/2004 10:19 PM
Have a 65 with a 230 and 3 speed. have read some posts on installing a T5 to better your highway speed. Maxed out a 60/65 not looking for and more speed just trying to lower the rpm's. Just trying to get the Pro & Con's from the guys in the know...Thanks in advance for any info.
1965 C-10 Stepside
#30253 11/10/2004 11:29 PM
A guy here called Mugsy just did that swap, his post is here ,look on the other pages.
#30254 11/11/2004 12:13 AM
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=008117
#30255 11/11/2004 2:34 AM
Yeah, I just did that swap on my 292. You're probably in a little better shape than I was with my 4.57 ring and pinion. What have you got, a 3.73 or 3.90?
I can't think of any cons in your situation. You've got the small tranny hump with the 3 spd so it might require a little more fabrication/modification/ingenuity.
I posted a bunch of files with text and pictures on my Yayhoo! group: Kustoms-and-Sleds
Unfortunately, you can't view the files unless you become a group member. So, you could join to look at the files and then un-join if you don't want to remain a member.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
