| | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30005 01/09/2005 4:41 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I got a shot at a good running 270 GMC to replace my tired 216. Will my bellhousing and/ or flywheel work with the 270 jimmy? My starter (6 volt), flywheel and pressure plate are in great shape. I would like to keep them. I also have a v8 T5 trans on the way. Can I make this package work? | | |
#30006 01/09/2005 10:34 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The bellhousing is no problem but GMC uses a different flywheel bolt pattern.
Early GMC used a four bolt flywheel, later they went to a six bolt but it is not the same pattern as Chev.
See the USA in your vintage Chevrolet! My Blog | | |
