0 members (), 206 guests, and 5 robots.
Topics128,089
Posts1,056,441
Members48,443
#29946 05/14/2005 10:09 PM
I recently purchased new leaf springs for my '52 3100. I was told not to powder coat them because the heating process would dis-temper the springs.
Does anyone have any advice on this?
Why would you want to powder coat them? PC does chip and water could get into the hole and spread between the PC and the steel. I have a PC mirror arm that chipped.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Would you suggest painting them?
I would suggest leaving them 'in the raw' the way that GM did - the first ones lasted 53 years, and prolly looked fine until they got abused too much - the constant flexing and sliding of the leaves against each other will make short work of anything else
Yeah, either leave them in the raw or throw some rattle can black paint on them and don't worry about them.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
I've seen recommendations to use industrial paint that is graphite or zinc rich. That said, I've heard of spring shops powder-coating springs. I'm not sure 450 degrees would be enough to do anything to the temper on the springs.
olblu, it sounds as if that mirror arm wasn't properly prepared or otherwise powder coated right, or you hit it hard with something...I've powder coated tools and had no trouble.
1954 GMC De Luxe COE
After reading the other thread, I stand corrected...powder coating is safe, as long as the temp stays below 350 degrees.
