1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#29814 04/14/2005 3:49 AM
Hi Guys and Gals
After some very slooowww work (2 years), I finally took my 49 3/4Ton in for its safety inspection prior to registering and insuring. Poor thing didn't study hard enough (sure, blame the truck!) and failed frown . One of the problems is the tie rod ends. They are too loose for my mechanic. Since it is easier (and safer), I will replace them. Problem is, I can't figure out which type I have. According to the 1954 shop manual I have, they appear to be the type reserved for 3/4T Forward Control and 1ton + trucks. The tie rod is hollow and threaded internally, and the ends screw in. The ends don't have the spring -and-socket setup I was expecting.
Is there a modern replacement I can get for this unit, or are the original ends still available? Any help is MUCH appreciated.
#29815 04/14/2005 12:05 PM
Obsolete Chevy has both the originals and the replacement stud types if you want to swap for something of a newer design.
Their website is not the greatest and doesn't have a picture of the tie rod end you're looking for but their catalogue shows them & they are right nice folks & real knowledgeable so they'd probably be willing to FAX you up page 66 from their catalogue & make sure you ordered the right unit.
Their phone # is 1-800-248-8785. They're on East Coast time (Nashville, GA outside of Atlanta)
Hope that helps.
Bodega Bob
http://www.submarinestore.com
Where's my tin foil hat?!?
