1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | Are all bolts outside or muat I drop pan how do I replace timing gear | | |
#2970 09/28/2004 10:09 PM | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The two bottom bolts on the timing cover are threaded through from inside the crankcase. Lots of people drill and tap for one size larger bolt during the job, so the pan doesn't have to be removed again. If there are two headless bolts at the bottom, yes, you will need to drop thew pan. Check on the condition of the rod and main bearings while you've got the pan off, and clean out the oil pump strainer screen, too! Jerry
