2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#2969 09/28/2004 3:49 PM
Apprentice
Apprentice
Are all bolts outside or muat I drop pan
how do I replace timing gear
#2970 09/28/2004 10:09 PM
H Online: Content
The two bottom bolts on the timing cover are threaded through from inside the crankcase. Lots of people drill and tap for one size larger bolt during the job, so the pan doesn't have to be removed again. If there are two headless bolts at the bottom, yes, you will need to drop thew pan. Check on the condition of the rod and main bearings while you've got the pan off, and clean out the oil pump strainer screen, too!
