| | | Forums66 Topics128,050 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29581 03/20/2002 9:04 AM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | howdy there partners i have finaly recieved the head gasket set now do i put a gasket glue on her or leave it clean thats for the head gasket and use sealer for everything else/ im talking 235 engine ex 1955 belair for my 46 pickup ive cleaned every thing up shes ready to roll also is it a idea to plug up the overflows from the rear brake drums so the oil doesnt contaminate the pads coming out of the diff?
p j a
#29582 03/20/2002 6:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | As for the headgasket, depends on which one you have. Usually instructions in the box that will tell you. If you got the copper headgasket, spray it with copper headgasket spray. If it's cardboard and colored blue, no dope is needed. Usually if it's cardboard and untreated, spray it with copper headgasket dope. Notice I said usually, that's why there should be instructions. If no instructions, call or go back to where you bought it and ask.
Fred 52 3600 69 C-10
#29583 03/20/2002 8:29 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | PETE I/ WE im sure, dont quite understand about[ over flows]and rear axel. NO LEAKING OF, BRAKE FLUID, OR GEAR OIL should be happening at all. you need to look at axel seals, and brake cylinders :confused: | | |
