0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29555 02/15/2005 2:31 AM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | Hi, Well I better ask the experts. You fella's know a heck of alot more than this guy. Have any of you used the metallic clutch disc's rather than the ordinary organic disc's?? What about the 6 point disc rather than the full clutch disc's? Any likes/or dis-likes there?
Also...I'm wondering what my ratio is in my diff on a 66 C20. Can I find it without pulling the cover? The number on the forward side of the diffy is 3883379 if that helps.
Thanks. | | |
#29556 02/15/2005 7:15 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Here are some resources for your axle codes. The axle code your looking for is on the Passenger side toward the front about half way between the diff and hub. It starts with 2 letters. Probably beginning with H. axle codes Hope this helps. | | |
#29557 02/15/2005 9:29 PM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | | | |
#29558 02/15/2005 10:01 PM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | A lot of BIG trucks (semi tractors) use the metallic disc. They are pretty aggressive and hold well. They also wear the flywheel surface more.
I guess it depends on what you are doing with your truck. If you are using for actual work, and are pulling heavy loads, I'd go with the 'metal' clutch. Any other light-duty use I would use the organic, as they are much more forgiving when engaging the clutch. | | |
#29559 02/15/2005 10:55 PM | Joined: Oct 2004 Posts: 26 Junior Member | | Junior Member Joined: Oct 2004 Posts: 26 | Thanks Racecarl. I think I'll go with a metallic disc. I pull trailers and my pickup will probably be used for some actual work now & then. Thanks guys. | | |
