8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible), 103 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
Did chev ever use a standard transmission behind a 400 small block engine? If so, in what applications?
I think the SBC 400 was primarily a truck engine in the '70s. So 3 or 4 speed truck trannys may have been used with them.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
I've heard of a balancing kit that allows using the flywheel from a 350 behind a 400. I don't know with certaintly whether Chevy ever put a manual transmission behind one or not.
They did offer a small block 400 through most of the 70's but by 1978 CAFE regulations started squeezing big cube engines out of the non-commercial market. I had a '78 4x4 with a 400 small block for a short time.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Hi Len,
I pulled a 400 small block out of my 65 short fleet and built it all the way, and was going to put it in a 66 long fleet to run for a couple of thousand miles untill I get the 305 built to go in the long bed and get the body for the 65 ready for the 400. Just checking a few things I noticed that the 400 didn't have the hole to screw in the ball for the torsion arm. I could have went to a hydraulic clutch set-up, but de-cided to go ahead and build the 305 instead. The 400 small block that came out of the 65 has a th400 tranny so there wasn't a clutch set up so that is one snag to using a 400 with a straight shift, although there may have been some used with a stick. I haven't seen one.
Truck Tinker from Talking Rock
I have one in a mid 70's dump truck but i don't think it's the original.the clutch and pressure plate should work from any of the small blocks just make sure your crank has the hole for the pilot bushing.You can get a balance plate to use any small block flywheel from speedway motors.
