3 members (Gdads51, Ol'55, Otto Skorzeny), 101 guests, and 2 robots.
Topics128,049
Posts1,055,649
#28624 03/14/2004 2:06 PM
Junior Member
Junior Member
We are working on our 51' Chevy 3100 that was setting out in our to decay for 2 years. We got started on it, and started with the engine.The engine is a 1954 Chevy 235, not the 219. We replaced the coil, points, condesor, spark plugs, and also rebuilt the carb. When it fired up though, it had a rough idle and backfire. Even after letting it run, adjusting the lifters, still no luck. When you turn the choke off after letting it idle and give it gas, it wants to quit, however the fuel pump is working perfect. Whats wrong with our beloved truck? Any help would be appreciated. Thanks!
#28625 03/14/2004 2:39 PM
ove Offline
Apprentice
Apprentice
U problably need to check the ignitiontiming, and possible leaks around carb.
#28626 03/14/2004 5:08 PM
Junior Member
Junior Member
I disconnected the vacuum line at the carburator, but I didn't plug the line.
Tim
#28627 03/14/2004 6:57 PM
Clean the mouse nests out of the exhaust pipes. You never know it could be that easy. wink
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#28628 03/14/2004 11:07 PM
You may have a sticking or burnt valve. Any valve noise? Backfiring usually means ignition getting back through the intake.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#28629 03/16/2004 1:38 AM
If you disconnected the line at the carb and did not plug the carb, you adjusted it with a massive vacuum leak. I usually just tune mine up with the line connected idling at 500 RPM. Since the distributor is connected to ported vacuum there is no advance at that RPM anyway.
Paint & Body Shop moderator
#28630 03/16/2004 3:29 AM
Make sure that you didn't cross a pair of plug wires. Make sure you have them in the correct order.
#28631 03/16/2004 3:44 AM
The one thing I haven't seen mentioned here is checking the points gap (or dwell.) If the gap is too small, it can result in backfiring thru the exhaust...and possibly thru the carb.
I'd take a look at the points (and look into the possibility of replacing them with a Pertronix Ignitor) as well as making sure that the firing order is correct and that there are no vacuum leaks.
