9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 52 | Will a new factory 3 core radiator cool well enough for a 1964 C-10 with a 350? It has an RV cam & flat top pistons with 76cc chambers with no other mods. The manufacturer says it will work with a 283 i that year but I'm not sure if the larger, slightly hopped up motor will be a problem...any suggestions?
Thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Mine runs fine on the factory radiator. I run the 350 and a four speed 75 mph all day if need be, Scott | | | | | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | A good shroud is VERY important in your success, or no around-town driving!
65 C10 292/700R4 long fleet...Gettin closer by the day.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Where can you get a shroud for a factory 64 rad? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wreckin yard - or try Scotts in Penhold Bill | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | articat53gmc:
I bought a new one from LMC Truck (lmctruck.com). I believe Chevy Duty also has them (chevyduty.com). Good luck in your search. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Thanks red and lilred. Next time i'm at scotts I might pick one up. | | |
