6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 49 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#2856 04/24/2005 1:13 AM
Will a new factory 3 core radiator cool well enough for a 1964 C-10 with a 350? It has an RV cam & flat top pistons with 76cc chambers with no other mods. The manufacturer says it will work with a 283 i that year but I'm not sure if the larger, slightly hopped up motor will be a problem...any suggestions?
#2857 04/24/2005 1:38 AM
Mine runs fine on the factory radiator. I run the 350 and a four speed 75 mph all day if need be,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#2858 04/24/2005 1:54 AM
A good shroud is VERY important in your success, or no around-town driving!
65 C10 292/700R4 long fleet...Gettin closer by the day.
#2859 04/24/2005 4:27 AM
Anonymous
Unregistered
Anonymous
Unregistered
Where can you get a shroud for a factory 64 rad?
#2860 04/24/2005 5:31 AM
wreckin yard - or try Scotts in Penhold
#2861 04/24/2005 6:16 AM
articat53gmc:
I bought a new one from LMC Truck (lmctruck.com). I believe Chevy Duty also has them (chevyduty.com). Good luck in your search.
#2862 04/24/2005 8:42 PM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks red and lilred. Next time i'm at scotts I might pick one up.
