0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 24 Junior Member | | Junior Member Joined: Apr 2003 Posts: 24 | Does anybody know what kind of bellhousing I would use on a 1974 nova 350 engine? Im going to put a saginaw 4 speed on it & then put engine & trans. in a 1950 pickup. THANKS | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Chevy V-8s from '55 on have all attached to the same bellhousings.
You will either be adding sidemounts for the motor and a crossmember for the transmission, or you need to front mount the motor and use a bellhousing that has mount pads, similar to what came out of your truck, but for the V-8.
I think sidemount and transmission crossmember are the best approach, I've seen it done the other way.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
