2 members (baldeagle, Ponchogl), 98 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#2852 11/19/2003 4:41 AM
Junior Member
Junior Member
Does anybody know what kind of bellhousing I would use on a 1974 nova 350 engine? Im going to put a saginaw 4 speed on it & then put engine & trans. in a 1950 pickup. THANKS
#2853 11/19/2003 6:35 AM
Chevy V-8s from '55 on have all attached to the same bellhousings.
You will either be adding sidemounts for the motor and a crossmember for the transmission, or you need to front mount the motor and use a bellhousing that has mount pads, similar to what came out of your truck, but for the V-8.
I think sidemount and transmission crossmember are the best approach, I've seen it done the other way.
