7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28176 08/05/2002 10:45 PM | Joined: Feb 2002 Posts: 4 Junior Member | | Junior Member Joined: Feb 2002 Posts: 4 | I am looking for a GM rear axle with 3.73 gears and a wheel mount to wheel mount dimension around 57.5". Does anyone know of a source vehicle with these specs? What is the rear end length in an S-10 blazer?
Thanks, Roger | | |
#28177 08/06/2002 2:39 AM | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | if it is going unde and a/d truck a nova or camero /transam r/e is a perfect fit .i used a 69 nova under mine and moved the rear shocks inside the frame rail to allow for more tie room it is a simple swap
47 Chevy COE..52 TO 30
#28178 08/07/2002 12:29 AM | Joined: Feb 2002 Posts: 4 Junior Member | | Junior Member Joined: Feb 2002 Posts: 4 | I'm going to put it under a '37 Chevy Coupe. I already have a rear end from a '70 Nova. It measures 60.5". It will fit but it really limits the wheel offsets available. Something around 57.5" would be much better. I know that a **** Granada rear end measures 57.5" but I would like to keep my GM car, all GM if possible.
Thanks, Roger | | |
#28179 08/07/2002 3:27 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | Get the Pford. After 64 GM went cheap on their rearednds and used the axle for the inner race of the bearing. If you get a rough bearing replace the axle and the bearing??? Pford has recently done this with their 8.8" rear. The 8" Pford will take a lot. This is from one with experience and have spent many $$$ on a Chevy 10 bolt. Hope this helps Dennis | | |
#28180 08/07/2002 10:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Some lincolns had 8.8 rear ends with disc brakes
#28181 08/10/2002 6:14 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | I found an 88 Blazer which fits perfect under the 38 Panel. The backing plate to plate is about 54 inches and it is a 373 posi.10 bolt. | | |
