2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#28176 08/05/2002 10:45 PM
Junior Member
Junior Member
I am looking for a GM rear axle with 3.73 gears and a wheel mount to wheel mount dimension around 57.5". Does anyone know of a source vehicle with these specs? What is the rear end length in an S-10 blazer?
Roger
#28177 08/06/2002 2:39 AM
if it is going unde and a/d truck a nova or camero /transam r/e is a perfect fit .i used a 69 nova under mine and moved the rear shocks inside the frame rail to allow for more tie room it is a simple swap
47 Chevy COE..52 TO 30
#28178 08/07/2002 12:29 AM
Junior Member
Junior Member
I'm going to put it under a '37 Chevy Coupe. I already have a rear end from a '70 Nova. It measures 60.5". It will fit but it really limits the wheel offsets available. Something around 57.5" would be much better. I know that a **** Granada rear end measures 57.5" but I would like to keep my GM car, all GM if possible.
Roger
#28179 08/07/2002 3:27 AM
Get the Pford. After 64 GM went cheap on their rearednds and used the axle for the inner race of the bearing. If you get a rough bearing replace the axle and the bearing??? Pford has recently done this with their 8.8" rear. The 8" Pford will take a lot. This is from one with experience and have spent many $$$ on a Chevy 10 bolt.
Hope this helps
Dennis
#28180 08/07/2002 10:32 AM
Some lincolns had 8.8 rear ends with disc brakes cool
#28181 08/10/2002 6:14 AM
I found an 88 Blazer which fits perfect under the 38 Panel. The backing plate to plate is about 54 inches and it is a 373 posi.10 bolt.
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
