3 members (Dennys28, Wayne67vert, 78buckshot), 108 guests, and 0 robots.
Topics128,134
Posts1,056,402
Members48,441
#28141 10/01/2003 12:40 PM
k10
Offline
I noticed that Bill Miles GMC motor has(Hi Bill) the oil filter on the passenger side attached to the block. The Chevies are on the driver's side and clamp to the manifold.
1.a. Can a clamp on style be utilized on a GMC?
b. can a clamp style be bolted to the block
without the clamps a la Bill's?
2. If so, was that style used originally in GMC?
3. where do the lines hook up?
228 GMC motor.
http://home.comcast.net/~bd97/EIFRAME.jpg
#28142 10/01/2003 12:59 PM
1. Yes (but it will look like $hit)
2. AC drop-in cartridge type mounted on a triangular bracket using three side cover bolts.
3. To the engine is usually best.
#28143 10/01/2003 2:34 PM
Anonymous
Unregistered
Anonymous
Unregistered
This is how the two GMC 228's I have are set up. I think this is only a GMC setup too. I have never seen one on a Chevy that came off a GMC engine. I am not sure the bolts would line up and then there is the location of the filter lines too. Different on the Chevy engines.
#28144 10/01/2003 3:27 PM
There are four holes in the bracket of a GMC style oil filter. The GMC and the Chevy engine used two completely different styles.
Remove the upper and lower two bolts in the front side of the push rod cover and the holes will line up to bolt on the filter canister..
Originally there were flex lines that connected the filter to the block. I used steel line for mine. My thought was that the canister was bolted to the block so the vibration would be non-existent...
k10, I have some pictures of the lines and canister taken while the engine was out.. I can E mail them to you if you are interested..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#28145 10/01/2003 11:57 PM
k10
Offline
You betcha, Bill. Thank You.
