| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27840 03/04/2004 2:02 AM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | Took my just finished 40' chev half ton out for it's second ride. Brake peddle went the floor! Had the master clinder "rebuilt" by an "expert" not long ago.It lasted about 5 miles. Fortunately, I was going slow on a back road checking everything out.No accident. That truck won't move til it has a dual master on it. The rebuilt 261 runs GREAT tho.Be careful out there. | | |
#27841 03/04/2004 5:17 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | It's good you're OK! I daily-drove my '48 for 10 years with a single reservoir MC. The MC outlet only needed one line but it had a tee fitting there. One of the branches had copper tubing that was crimped with a pair of pliers. There were also pipe fitting unions in the system. I'm sure glad that I now have a dual reservoir MC with all new lines and double flared fittings. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#27842 03/04/2004 5:38 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Did you replace with a dual master in the stock location? If so, was that an aftermarket or is there a junkyard replacement that can be made to work. I have been driving my 48 daily with a single for 6 months and I have read many posts talking about the singles failure, but no idea what they used to replace them with. Thanks!! | | |
#27843 03/04/2004 7:29 PM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | Am lookin into the problem now with a guy who's done many dual masters on old trucks. Will give a full report soon as I'm sure my info is CORRECT. | | |
#27844 03/04/2004 8:53 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | The original idea of a dual master cylinder is to improve safety. I know, duh. But wait, many brake failures are from other causes than a bad MC. A leak anywhere else in the system can put your pedal on the floor with no stopping power. Rotten brake lines and hoses, bad wheel cylinders and worn out shoes and drums probably cause more brake failures than do bad MC. I agree with Ralphy, it warrants a thorough investigation of the cause. A dual master alone may not fix it. Good luck.
Professional Novice
#27845 03/04/2004 9:11 PM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | thanks guys. ALL the brake system ,except the peddle,is new except the master cyl which is rebuilt.Brakes are kinda important(which is why I posted my brake failure)so I took the truck to a old,experienced brake shop(owner has a 40's panel truck).He confirmed my view that it IS the single master that failed. Will post the problem as soon as I can do it accurately. I'm kinda new to this stuff. | | |
#27846 03/05/2004 3:18 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | A good search here should net a lot of posts and pictures on this topic. I went with the '69 Mustang front disc model, even though I'm using it for four wheel drum right now. I got my bracket from ECI, but you need to verify some applications as some tranny linkages are very close by. Should be no problem if you have a four speed, three on tree and hydramatics need a close look, or you may have to modify or clone a special bracket. The MC has a pedal rod with a big eye on the end. That will need to be cut off, and the rod should be ground down so you can run a thread onto it, for a rod coupling in some cases or a heim joint in others. Stovebolter Bill Miles graciously provided some excellent photos of his installation on a '53 gmc hydramatic truck. Look for his web site for for information.  | | |
#27847 03/05/2004 5:41 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm new to this site and this is my first forum response.What I did on my '48 4400 to make my brakes more safe was to install a double line master for a '66 Pontiac Catalina. It is for a 4 wheel drum brake system which doesn't require a proportioning valve. Also, the truck has a V-8 in it and the left exhaust pipe heats up the master, making it neccassary for a heat shield. On the other hand, I've been driving my '64 for 3 years with out any problems. ood luck with your brake set-up! | | |
#27848 03/05/2004 6:51 AM | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | Thanks ALL! 48bigtrucks, howdy 'n welcome . I'm pretty new here too. We bled my brakes and they're working fine now. I don't trust them tho and will follow advice from this thread and my other one"Brake cylinder failed,part2"(or something like that).Tomorrow I'm gonna tighten every connection on the whole system. I'm looking into a dual master too. Your experience is interesting 'n I'll check it out. Thanks ALL,again. jim | | |
