1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#27827 11/06/2002 11:22 PM
Can someone tell me the GM part # for a 1960 hydraulic lifter for a 235?
Is the part # the same for the 54-58 and the 59-62 Hydraulic lifter for the 235?
Are the hydraulic lifters for the 235 and the 261
identical?
#27828 11/09/2002 5:17 AM
This new guy sure got a lotta answers.
54 3100 with 235
62 flatbed dump C60 with 261
#27829 11/09/2002 4:52 PM
Rusty, I bought hydraulic lifters for my '53 235 before I knew I was switching to a '61 261. The US truck 261's came with solid lifters even though they were drilled for hydraulics (check your block) The Canadian Pontiac 261's had hydraulics. It's my understanding that my 235 lifters would fit my 261. What gives me concern is NAPA had two different part #'s for the 235 and 261 hydraulics. I'll think I'll do an exchange.
Check out Jim Carter's piece on the 261 if you haven't already read it.
http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/00900.2.2276781697922088411
#27830 11/09/2002 5:13 PM
Have you folks priced solid lifters for the 235 lately! Parts America was $22 ea. and NAPA was $20 each with Clifford cams coming in at $130/set. Needless to say, I was shocked and ended up buying from Patricks for $70/set of 12.
PRW
#27831 11/09/2002 6:16 PM
Rusty46
Here's the '59 parts book stuff on 235 lifters.
41-55 ALL (235) (exc. P.G.).......................w/rod seat (yellow paint under rod seat) p/n 3660438
53 PASS. w/P.G.................................... hydraulic type (3 holes on side) (HL-17) p/n 5230850
54-55 PASS. w/P.G. (6 cyl.),
56-58 PASS. (6 cyl.) (exc. '58 TAXI)........... hydraulic type (1 hole 1/8") (HL-18)....... p/n 5231450
58 TAXI w/3752735 cam (6 cyl.),
59 PASS. (6 cyl.).................................. hydraulic type (HL-31)............................ p/n 5231830
The only 261 listings are mechanical (book only goes thru '59')
54-55 UTIL. (261)..................... mechanical type, single groove around body......... p/n 3836342
56-59 Ser. 3-4-6 (6 cyl.)........... mechanical type...................................................... p/n 5231800
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#27832 11/09/2002 6:17 PM
Hi Guys
Thanks for your help. I have a 60 261 short block and a 55 848 head. I have really appreciated the thread started by Stingray regarding block and head oiling. Thank you Chip for being so persistent with your questions. I also need the rocker arm oiler/connector if you find two.
Thank you Tony and Olblue for your in debth research regarding 235 261 engine oiling and interchangeability. I hope the meat of that thread is preserved for others to come.
Now I'm dealing with the hydralic lifters. I've also found 2 part #'s for the hydralic lifters.
How about it Tony? Olblue? Somebody must have some part #'s for these lifters to determine interchangeability/application. Help please.
Regards to all, John
#27833 11/09/2002 6:42 PM
OlBlue et al
Do you have an application for hydraulic lifter part # 5230920 ?
Thank you for your help!
#27834 11/09/2002 6:59 PM
Rusty46,
No joy on that number in the books I have.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
#27835 11/09/2002 7:23 PM
Thanks OlBlue
I appreciate the lookumup
