| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#2762 04/18/2004 10:07 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Can any of you truck folks out there give some clue as to what type and year of motor I've got. It looks like a combination of a 216 (top studs) or a 235. The casting on the block is 3701887. a Canadian motor. | | | | | Joined: Mar 2004 Posts: 25 Member | | Member Joined: Mar 2004 Posts: 25 | Is there a date casting # such a A81 on the rear of the engine? I have a good selection of books that provide decoding of engine casting #s and date codes for 55 and newer engines. I suspect they used the same methods for identification. | | | | | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Are you sure the number came from the block? The only place I could find that said anything it that "3701887" corresponds to the head off of a 1953 Chevy 235. Hope this helps. -Shane
Whad you do?!?
Shane 1953 Chevrolet 3600
#2765 04/20/2004 12:54 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Shane you are right, it is a head casting number. Where was my head!!! As far as any other numbers are concerned, the stamping on the right side of the block near the starter is - 0299232T54Z. Remember this is a Canadian blocxk. Thanks guys. | | |
