0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#2762 04/18/2004 10:07 PM
Can any of you truck folks out there give some clue as to what type and year of motor I've got. It looks like a combination of a 216 (top studs) or a 235. The casting on the block is 3701887. a Canadian motor.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#2763 04/19/2004 5:45 AM
Is there a date casting # such a A81 on the rear of the engine? I have a good selection of books that provide decoding of engine casting #s and date codes for 55 and newer engines. I suspect they used the same methods for identification.
#2764 04/19/2004 6:00 AM
Are you sure the number came from the block? The only place I could find that said anything it that "3701887" corresponds to the head off of a 1953 Chevy 235. Hope this helps. -Shane
Whad you do?!?
Shane
1953 Chevrolet 3600
#2765 04/20/2004 12:54 AM
Shane you are right, it is a head casting number. Where was my head!!!
As far as any other numbers are concerned, the stamping on the right side of the block near the starter is - 0299232T54Z.
Remember this is a Canadian blocxk.
Thanks guys.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
