I have a 1938, 1/2 ton with the stock 216 and 3 speed transmission. Needless to say, a top speed of 45 mph just doesn't cut it. I see discussions about a modified ring and pinion for the rear end, but it appears, that'll only get me 5-7 mph, yes?
If my research is correct, in 1939 they started using a 4 speed. In fact, I've noticed that most of the 1 ton and larger trucks ALL use a 4 speed.
Other than not being original, would there be any problems with me bolting a 4 speed onto my 216? Will it solve my "top end" problem? Can a guy that had never changed his own oil until acquiring the aforementioned vehicle handle the wrench work????
Thanks in advance for any and all input!
Jesse
