| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26090 03/21/2005 3:28 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I may have posted this before but I forget(easily). I bought brake shoes for my 49 front and rear. Raybestos 141PG. The four shoes in one box had linings longer than the other. As the 49 shoes are the same on both sides of the axle I could always put the longer set on the front and the shorter on the rear. Someone said I should split the difference and put the longer lined shoes on the backing plate facing the front of the truck (front and rear) and someone suggested the longer lined shoes should go on the backing plates facing the rear of the truck. I am easily confused. I think this might apply on bendix brakes where one shoe is longer. | | |
#26091 03/21/2005 3:47 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | blu - on the TF trucks [bendix] one shoe in each wheel is longer - the one on the rearward side of each, which is called the secondary shoe, and does more of the braking - if you have the 'huck brakes' it might be different, and maybe they gave you the wrong parts - don't think you wanna make it so any wheel has 2 longer shoes
Bill | | |
#26092 03/21/2005 6:37 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Bill, the brakes are Huck style and the shoes/linings on each wheel are equal length. They can in fact be reversed if there is wear on one. Having a box of shoes which is about one inch longer than the other box, both same part number, perhaps I can put the longer shoes entirerly on the front. | | |
#26093 03/22/2005 3:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | On huck brakes the front shoe is going to do most of the braking. I would put the long shoe in front. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#26094 03/23/2005 9:04 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Wrenchbender you are mistaken. Here is a link to Raybestos counterman training page. http://www.raybestos.com/OnLineTraining/cpt-007.htm The larger shoe will go in the rear position. Hope this clears things up for you!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#26095 03/23/2005 9:54 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | So Bendix brakes are self-energizing... Are Huck brakes self energizing? I am pretty sure that my 54 had Bendix brakes on it.
Gord 1954 1/2 ton 235 4 speed
#26096 03/23/2005 11:11 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Gord. In 54 it did. My 53 has them. | | |
#26097 03/23/2005 11:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | OK I went to your training center sight. It shows that 70% of the brakeing is on the front shoe on non-servo brakes which is what huck brakes are. I believe I would want the most braking on the longest shoe. Huck brakes were used on 1/2 tons 1950 on back. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#26098 03/24/2005 2:29 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that it is incorrect to have unequal length linings on the Huck brakes. Have you compared the metal part of the shoes to your old ones? If they are for Bendix brakes, the metal form will be different. | | |
#26099 03/24/2005 4:02 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | The front brakes on 49 or at least on MY 49 are "huck" brakes or NON Servo brakes. However my rear brakes are Servo style.
Now if I understand the original post "The four shoes in one box had linings longer than the other." Olblu49 has 2 sets of brake shoes. One set of four is longer then the other set of 4.
If it were me I would put the longer set on the front brakes. As they do most of the braking. I would not mix and match lengths between the boxes.
Good luck
#26100 03/24/2005 4:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Brian if you have servo type brakes on the rear they have been changed at sometime because they didn,t come out that way. It,s true the linings should be the same length. Old blue you might take that back to the supplyer & check with them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#26101 03/24/2005 6:43 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Brian you have my post right. Two boxes of shoes, 4 shoes with 1 3/4" wide by 11 1/4" long lining and the second set of 4 shoes with linings that are 1 3/4" by 10 1/2" long. Both are from Raybestos p/n 141PG. If I keep them I will put the longer linings on the front wheels. The shoes themself are identical. Now another thing has come up. I want extra friction (FF)linings and the edge code on the shoes should show it in a serial/compound number. These shows show nothing. After more inquiries it was suggested that these may be counterfeit shoes! More research to come. | | |
