0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#25920 04/26/2005 10:37 AM
the truck is 1 inch or more closer to garage floor on pass side than drivers this is visiable if you stand back some and look. It has leafe springs on front and back also knee action shocks .Do I need springs? or shocks? or something else is there a test of some kind--it is a 40 suburban carryall. thanks Bill
#25921 04/26/2005 10:51 AM
My guess would be the springs.Are there the same no.of leaves in each side?Are these the original springs?If so one could have been changed and is stronger than the other.This is where I would start investgating.I am sure some of these other guys will chime in with some good advice.
#25922 04/26/2005 1:18 PM
If the problem is springs, the frame will tilt to one side. Measure the floor to frame distance at the same point on either side to confirm.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#25923 04/26/2005 1:21 PM
look at your floorboards sometimes the innerkick panel rusts away from the floor which allows the truck to settle. mine is that way on the drivers side. i wiil have to replace the innner and outer panels. i also thought springs but not so. still that way after a pacer IFS transplant. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#25924 04/26/2005 10:13 PM
Riding in the Passing Lane
Also check your spring pin & shackle bushings.
1972 Chevy c10 Cheyenne Super
#25925 04/27/2005 12:10 AM
I had the same problem. Here is what I did to fix. All done at home. Replaced the shocks all the way around, replaced the shackles and pins on the leaf springs. Noted that the clasp that holds th leaves in alignment were shot sot I made and insalled new ones. Took me a weekend and about $200.00 in parts, but he's (trucks are only males) trued-up now with or without the load. Got the shocks from a local auto house, the spring shackles kits from Chevy Duty, and made the clasps out of 3/4" wide flat steel with u-bolt helpers.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
#25926 04/27/2005 1:49 AM
Jeff Nelson Masured floor to frame 1 inch closer to floor pass side in front and in rear.
Wrenchbender will check spring pins and shackle bushings.
50-Four-Bruce plan to remove springs and inspect everything.- The 40 has knee action shocks have not found any replacements yet. May have to go to later model shock, and make shock brackets. thanks for the info. Bill
#25927 04/27/2005 6:30 PM
I had these interesting coil overload springs on my 49. Rode rough but sat square. Took out the coils and the rubber cover on one was worn right to the metal coil. The other was okay. However once the coils were out the truck leaned to one side. Local spring shop took the leaf spring apart and re-arced them. Fine now.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
