2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25920 04/26/2005 10:37 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | the truck is 1 inch or more closer to garage floor on pass side than drivers this is visiable if you stand back some and look. It has leafe springs on front and back also knee action shocks .Do I need springs? or shocks? or something else is there a test of some kind--it is a 40 suburban carryall. thanks Bill | | |
#25921 04/26/2005 10:51 AM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | My guess would be the springs.Are there the same no.of leaves in each side?Are these the original springs?If so one could have been changed and is stronger than the other.This is where I would start investgating.I am sure some of these other guys will chime in with some good advice. | | |
#25922 04/26/2005 1:18 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | If the problem is springs, the frame will tilt to one side. Measure the floor to frame distance at the same point on either side to confirm.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#25923 04/26/2005 1:21 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | look at your floorboards sometimes the innerkick panel rusts away from the floor which allows the truck to settle. mine is that way on the drivers side. i wiil have to replace the innner and outer panels. i also thought springs but not so. still that way after a pacer IFS transplant. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#25924 04/26/2005 10:13 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Also check your spring pin & shackle bushings. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#25925 04/27/2005 12:10 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I had the same problem. Here is what I did to fix. All done at home. Replaced the shocks all the way around, replaced the shackles and pins on the leaf springs. Noted that the clasp that holds th leaves in alignment were shot sot I made and insalled new ones. Took me a weekend and about $200.00 in parts, but he's (trucks are only males) trued-up now with or without the load. Got the shocks from a local auto house, the spring shackles kits from Chevy Duty, and made the clasps out of 3/4" wide flat steel with u-bolt helpers.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#25926 04/27/2005 1:49 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Jeff Nelson Masured floor to frame 1 inch closer to floor pass side in front and in rear. Wrenchbender will check spring pins and shackle bushings. 50-Four-Bruce plan to remove springs and inspect everything.- The 40 has knee action shocks have not found any replacements yet. May have to go to later model shock, and make shock brackets. thanks for the info. Bill | | |
#25927 04/27/2005 6:30 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I had these interesting coil overload springs on my 49. Rode rough but sat square. Took out the coils and the rubber cover on one was worn right to the metal coil. The other was okay. However once the coils were out the truck leaned to one side. Local spring shop took the leaf spring apart and re-arced them. Fine now. | | |
