4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
#25901 10/28/2005 5:22 PM
I am going to run a 2X1 offenhauser manifold on a 235. Which carb is better the Carter Y-F 2100 or the Rochester?
#25902 10/28/2005 6:34 PM
H Online: Content
"The ABC's of carburetion are Always Buy Carter". At least that's what Carter's ad copy read in the early 1950's. The only thing a Rochester does better than a Carter is LEAK! Now, if you'll just run one carb instead of two, you'll cut your problems in half, and then some. Other than looks, there's no reason to run multiple carbs on a stovebolt.
#25903 10/28/2005 10:29 PM
Jerry - I know you are right for the most part, but It hurts to hear you say that frown
I'm installing an Edelbrock 2X1 w twin Rochesters sometime this winter. Currently my truck runs GREAT w the original Rochester. It has never leaked and the truck will start instantly when warm. When it hasn't been started in a couple of weeks I simply pull the choke, pump it once and you might hear the starter turn once or twice before it starts. In short, it starts faster than any fuel injected car I've ever had. (a long list). Also, if I drive like my wife, I can get up to 20 mpg. I average 16-17. So why am I going to the 2x1? I think I need my head examined. :confused:
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#25904 10/28/2005 10:33 PM
If it an't broke,,,,,,,,,,,,,,,,,,,,,,,,Fred
Redryder pix
My Hotrod
#25905 10/28/2005 11:50 PM
I have a 1954 4400 1.5 ton (34k orginal miles) that runs great but 50 mph max. I need to get 58-60 mph for what I use it for. The plan is a brownie auxilary trans, the corvette split exhaust manifold and 2X1 carbs. I believe the combo will work fine. The brownie alone will give me the gears but I will run out of engine therefore I need more fuel and beathing. I may even go to a 261.
#25906 10/29/2005 12:44 AM
ROUGIE,
Your rig is the same as mine...don't keep me in suspense, post a pic!! Mine is actually a 55/1st, but why split "hares". grin
Stuart.
#25907 10/30/2005 1:30 AM
It depends on what you expect from the 2 x 1 carb setup. On my 1954 sedan with a 235 engine, adding a 2 x 1 with Rochester carbs added 8 m.p.h. to my 1/4 mile speed at the drags. I went from 77 mph to 85 with no other changes. Stock exhaust manifold with 2nd outlet added between rear two exhaust ports on both carburetion setups. Mileage went down about 2 m.p.g. but I thought the extra power was worth it.
