0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25901 10/28/2005 5:22 PM | Joined: Oct 2005 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 43 | I am going to run a 2X1 offenhauser manifold on a 235. Which carb is better the Carter Y-F 2100 or the Rochester? | | |
#25902 10/28/2005 6:34 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | "The ABC's of carburetion are Always Buy Carter". At least that's what Carter's ad copy read in the early 1950's. The only thing a Rochester does better than a Carter is LEAK! Now, if you'll just run one carb instead of two, you'll cut your problems in half, and then some. Other than looks, there's no reason to run multiple carbs on a stovebolt. Jerry
#25903 10/28/2005 10:29 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Jerry - I know you are right for the most part, but It hurts to hear you say that I'm installing an Edelbrock 2X1 w twin Rochesters sometime this winter. Currently my truck runs GREAT w the original Rochester. It has never leaked and the truck will start instantly when warm. When it hasn't been started in a couple of weeks I simply pull the choke, pump it once and you might hear the starter turn once or twice before it starts. In short, it starts faster than any fuel injected car I've ever had. (a long list). Also, if I drive like my wife, I can get up to 20 mpg. I average 16-17. So why am I going to the 2x1? I think I need my head examined. :confused: | | |
#25904 10/28/2005 10:33 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | If it an't broke,,,,,,,,,,,,,,,,,,,,,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#25905 10/28/2005 11:50 PM | Joined: Oct 2005 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 43 | I have a 1954 4400 1.5 ton (34k orginal miles) that runs great but 50 mph max. I need to get 58-60 mph for what I use it for. The plan is a brownie auxilary trans, the corvette split exhaust manifold and 2X1 carbs. I believe the combo will work fine. The brownie alone will give me the gears but I will run out of engine therefore I need more fuel and beathing. I may even go to a 261. | | |
#25906 10/29/2005 12:44 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ROUGIE, Your rig is the same as mine...don't keep me in suspense, post a pic!! Mine is actually a 55/1st, but why split "hares". Stuart. | | |
#25907 10/30/2005 1:30 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | It depends on what you expect from the 2 x 1 carb setup. On my 1954 sedan with a 235 engine, adding a 2 x 1 with Rochester carbs added 8 m.p.h. to my 1/4 mile speed at the drags. I went from 77 mph to 85 with no other changes. Stock exhaust manifold with 2nd outlet added between rear two exhaust ports on both carburetion setups. Mileage went down about 2 m.p.g. but I thought the extra power was worth it. | | |
