6 members (Gdads51, Otto Skorzeny, TUTS 59, amtrakjoe, fonz8261, mk72), 78 guests, and 3 robots.
Topics128,043
Posts1,055,524
Members48,424
#25356 03/11/2004 2:31 AM
Well, the machine shop just notified me that my tired 235 is already bored .060 over and the crank has been turned .010. What is the recommended maximum bore for a 235 ... is .080 ok for a daily driver?
..... or should I just start searching for another 235 or a 261. The 848 head on my 235 is in very good shape, per the machine shop.
I have all the external parts for the 235, including flywheel, bellhousing, starter, etc.
Can those be used on a 261 if I find one?
#25357 03/11/2004 6:59 AM
Oly Offline
If you aren't working the truck in hot temps or real hard all the time, boring a 235 to .080 over is a good way to go. I wouldn't do it to a hard working truck though. You'll end up with cooling problems. Lots of metal in 235's and I have seen them 120 over, but I sure wouldn't go that far. If you take good care of your engine you will have no problems. The crank can go to at least .020 over.
About your second question- YES!!!
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#25358 03/11/2004 3:25 PM
Well, back in the day when these engines were newer, the hotrodders would take them .080 to .125" over. But since these engines are so old now, rust and corrosion have eaten at the water jacket side of the cylinder wall. Its best to have any block sonic checked for wall thickness when boring above .060". Cheap insurance before you go ordering special pistons, rings, balancing, boring, etc, just to find out you've struck water or warped a cylinder.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
