3 members (wilbur53, JW51, Otto Skorzeny), 150 guests, and 5 robots.
Topics128,088
Posts1,056,124
Members48,435
#24917 07/01/2003 5:42 PM
I've currently got a parts wanted ad in the Swap Meet for brake drums for my 1953 3/4 ton Chevy pickup. I know that the same drum was used from 1953 to 1959.
I have now been told that the same drum was used on 1960-1970 3/4 ton 4 wheel drive pickups. Does anyone know that for sure? Anyone got a picture of one online? If I can confirm this information, it will hopefully make it more likely that I will be able to find the parts I am looking for.
Thanks in Advance (Design)
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#24918 07/01/2003 6:17 PM
No photos of the 8-lug, but you can find reproduction (made in China) drums here, among other distributors.
I just ordered a repro front drum from LMCtruck and it's a bolt-on fit. grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#24919 07/01/2003 6:43 PM
Thanks, Hedgehog. I know repros are available from many of the standard vendors, and that will be the route I take if I can't find either NOS or excellent quality used.
I know that for brake parts, the Chinese repros need to meet DOT specifications, but I just don't think they will be as good of quality as the originals. I keep having this image of Chairman Mao's "Great Leap Forward" in the 50s and all of these folks in China building small steel smelters in their backyards. grin
Jeff Nelson
#24920 07/02/2003 7:19 AM
Not sure when they changed in the 60`s but the drums were changed to an inboard design which made the removal of the drum and hub as an assembly a requirement.
The earlier style had three screws which could be removed and the drum could be removed with the hub still left in place on the axle assembly.
#24921 07/03/2003 12:50 AM
I know the brake drums are the same into the late sixites on the half tons also,check with autozone or any other part store. I was going to update my 37 with 51-up brakes and checked with autozone and they could get everything to rebuild and even had a drum in stock,if they can get parts for a half ton they probably can for 3/4 tons too. The drums are the same on the front and back of a half ton,the 3/4 tons might be the same also.
#24922 07/03/2003 9:43 AM
3/4 ton front drums are 2 X 11 , rear drums are 2& 1/2 X 12
#24923 07/03/2003 8:48 PM
I just got a 3/4 ton rear from a 59??? panel. I will check out the drums if you like. I mainly bought it for the pumpkin. It was hanging on the truck in the crusher pile at a salvage yard. Luckily, i got the rear before it was crushed. frown
#24924 07/04/2003 4:30 AM
What ratio are the gears in that panel?
#24925 07/04/2003 5:46 AM
I'm not sure yet. I will try to check it out this weekend & post the info. It is still 'swingin from the boom truck smile
#24926 07/05/2003 5:39 PM
I pulled the cover & they are 5.14's. Have a '66 date stamped on the ring gear so someone must have replaced the pumpkin. Open diff. It has larger brake drums than a '66 rear end I saved the drums & hubs from. I think I can get my hands on a 4.11 pumpkin if that is what you need. smile
#24927 07/05/2003 7:23 PM
Jeffspower, sounds like you may have the "rare" 14" rear drums for the 1-ton, and 5.14:1 is a common tonner ratio.
#24928 07/05/2003 7:59 PM
I believe they didn't make a 3/4T task force panel - woulda been 1T, much longer body, so that's prolly right Hedgehog
#24929 07/05/2003 8:05 PM
Your right squeeze. in that thew 5:14 gears were used in the 1 ton p/up like I have, and it had a 9' bed on it.
Collecting is fun, as long as momma enjoys riding in them.
#24930 07/06/2003 2:50 AM
Quote
Luke,
What year(s) are you referring to here?
Jeff Nelson
#24931 07/06/2003 2:56 AM
Yep, hedgehog must be right- [quote]sounds like you may have the "rare" 14" rear drums [unquote]
At least that is about what they measure on the outside. wink
