1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24917 07/01/2003 5:42 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | I've currently got a parts wanted ad in the Swap Meet for brake drums for my 1953 3/4 ton Chevy pickup. I know that the same drum was used from 1953 to 1959.
I have now been told that the same drum was used on 1960-1970 3/4 ton 4 wheel drive pickups. Does anyone know that for sure? Anyone got a picture of one online? If I can confirm this information, it will hopefully make it more likely that I will be able to find the parts I am looking for.
Thanks in Advance (Design)
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#24918 07/01/2003 6:17 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | No photos of the 8-lug, but you can find reproduction (made in China) drums here, among other distributors. I just ordered a repro front drum from LMCtruck and it's a bolt-on fit.  | | |
#24919 07/01/2003 6:43 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Thanks, Hedgehog. I know repros are available from many of the standard vendors, and that will be the route I take if I can't find either NOS or excellent quality used. I know that for brake parts, the Chinese repros need to meet DOT specifications, but I just don't think they will be as good of quality as the originals. I keep having this image of Chairman Mao's "Great Leap Forward" in the 50s and all of these folks in China building small steel smelters in their backyards.
Jeff Nelson
#24920 07/02/2003 7:19 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Not sure when they changed in the 60`s but the drums were changed to an inboard design which made the removal of the drum and hub as an assembly a requirement. The earlier style had three screws which could be removed and the drum could be removed with the hub still left in place on the axle assembly.
#24921 07/03/2003 12:50 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I know the brake drums are the same into the late sixites on the half tons also,check with autozone or any other part store. I was going to update my 37 with 51-up brakes and checked with autozone and they could get everything to rebuild and even had a drum in stock,if they can get parts for a half ton they probably can for 3/4 tons too. The drums are the same on the front and back of a half ton,the 3/4 tons might be the same also. | | |
#24922 07/03/2003 9:43 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 3/4 ton front drums are 2 X 11 , rear drums are 2& 1/2 X 12
#24923 07/03/2003 8:48 PM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | I just got a 3/4 ton rear from a 59??? panel. I will check out the drums if you like. I mainly bought it for the pumpkin. It was hanging on the truck in the crusher pile at a salvage yard. Luckily, i got the rear before it was crushed.  | | |
#24924 07/04/2003 4:30 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What ratio are the gears in that panel?
#24925 07/04/2003 5:46 AM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | I'm not sure yet. I will try to check it out this weekend & post the info. It is still 'swingin from the boom truck  | | |
#24926 07/05/2003 5:39 PM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | I pulled the cover & they are 5.14's. Have a '66 date stamped on the ring gear so someone must have replaced the pumpkin. Open diff. It has larger brake drums than a '66 rear end I saved the drums & hubs from. I think I can get my hands on a 4.11 pumpkin if that is what you need.  | | |
#24927 07/05/2003 7:23 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Jeffspower, sounds like you may have the "rare" 14" rear drums for the 1-ton, and 5.14:1 is a common tonner ratio. | | |
#24928 07/05/2003 7:59 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I believe they didn't make a 3/4T task force panel - woulda been 1T, much longer body, so that's prolly right Hedgehog
Bill | | |
#24929 07/05/2003 8:05 PM | Joined: Feb 2003 Posts: 58 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 58 | Your right squeeze. in that thew 5:14 gears were used in the 1 ton p/up like I have, and it had a 9' bed on it.
Collecting is fun, as long as momma enjoys riding in them.
#24930 07/06/2003 2:50 AM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Originally posted by Mechainiac: 3/4 ton front drums are 2 X 11 , rear drums are 2& 1/2 X 12 Luke, What year(s) are you referring to here? Thanks
Jeff Nelson
#24931 07/06/2003 2:56 AM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | Yep, hedgehog must be right- [quote]sounds like you may have the "rare" 14" rear drums [unquote] At least that is about what they measure on the outside.  | | |
