1 members (Oswald),
243
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24885 03/01/2004 1:35 AM | Joined: Feb 2004 Posts: 2 Junior Member | | Junior Member Joined: Feb 2004 Posts: 2 | I am putting a 302 GMC into my '49 GMC 3/4 ton. My original 4 speed will not bolt up to the bellhousing of the 302. The 5 speed on the 302 is a monster, and doesn't fit well on the frame with my power master cylinder. Anyone know of a smaller GMC transmission that will bolt up to my 302 bellhousing?? I could use the bellhousing from the 228, but that would require turning down the flywheel, and I am not too interested in doing that (would require 1.5-2 inches of reduction)....any suggestions?? Thanks Jon | | |
#24886 03/01/2004 2:08 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Sounds like the tranny is a Clark 5 speed which is highly sought after.
I had the same problem installing a 302 in my 51 GMC 1 ton. I was able to use my old 228 bellhousing after finding a 6 hole 248 flywheel which is the same thickness as the 4 hole 228 flywheel. I think a 270 flywheel will work too. Then I had to order a new pressure plate at Napa for the 248 FW because the 228 PP had a different hole pattern where the PP bolted on.
Do a search under GMC flywheel and you will find a few inquiries I made and some info that should help you. One of the replies mentioned which years of 248 or 270 flywheels I should look for.
By the way, I found a used 248 flywheel at a junkyard in Windsor, Colorado. I think it cost about $80 shipped. Martin Supply & Salvage, 970-686-2460 | | |
#24887 03/01/2004 3:50 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Welcome to the Stovebolt Page....Nice Stovebolt name too.
Five Speed Clark??? What is that? | | |
#24888 03/01/2004 4:27 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Here's a site with probably more than you want to know about GMC transmissions. It lists the gear ratio's for Clark 5 speeds. http://www.6066gmctrucks.org/SM420.htm According to my 47-54 GMC manual the 5 speeds were found in 400 series trucks. | | |
