5 members (klhansen, 5 Window 9434, farmallb, Peggy M, 1 invisible), 59 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#2485 04/01/2005 3:35 AM
When I started to install my balancer on a 235 from my'54 3104 I was surprised it slipped right on. It was flush against the crank gear at the back but there was about 5/8 inch distance between the end of the crank and the step up in the inside of the balancer. I didn't take it off but I am assuming the damper should go on far enough to bottom against the crank and the raised portion of the inside of the balancer.
I have always seen crank gears with two threaded holes like the balancer and the cam gear but this crank gear has no holes on the side facing out.
Could my machine shop have installed the crank gear on the wrong side?
I know this sounds stupid to all you guys that do your own engine rebuilding but I'm lost.
My rule of life: You can have anything you want; you just can't have everything you want.
If you can see the circles or dots for gear alignment your okay. Not all timing gears have threaded holes. The 235 metal gear is aluminum, which would strip out with a puller.
The balancer doesn't necessarily match with the end of the crank, but the loose fit worries me. Did you have the balancer rebuilt? If not, I would get it done. Also, did the mechanic drill and thread the crank snout for a bolt? Useful for retaining a balancer.
Fred
52 3600
69 C-10
did you install the half moon key in it?
Redryder pix
My Hotrod
