2 members (baldeagle, Hotrod Lincoln), 50 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#246813 03/14/2007 1:38 PM
Posted this in the "Doors" section first but got no replies. Where can I buy window seals for the windows in the back barn doors? Looked in Steele Rubbers online catalog but didn't really see them listed. The windows are the only ones of all 14 that aren't broken, cracked or cloudy. I can use them over. They are the only ones also that are not flat glass. Finding them might be a real pain. Weeds
#246814 03/14/2007 3:45 PM
call Steele Rubber Products
#246815 03/14/2007 5:44 PM
I used panel-body rear-door window seals from Jim Carter(WI1371). These types of rubber channels tend to dry out and shrink after they are installed. Do not cut it too short (on purpose, I cut it too long) and keep it dressed with a non-silicone-based rubber dressing.
#246816 03/16/2007 2:05 AM
1 Offline
I neede rear quarter window seals for my nash sedan.I looked high and low with no luck. I mailed one with a letter to steeles. They did a very nice job matching it to something I was able to modify. The end result looked very nice and I was happy they took the time to set me up....my 2 cents
restoring a 1946 coe wrecker.
#246817 03/16/2007 11:37 AM
Weeds,
If you want the best, as red58 suggests, check out Steele Rubber Products. It looks like the part number is 60-0380-81 ($77.80 per pair).
Tim
#246818 03/25/2007 6:04 PM
Thanks Tim, Bill and 1916 signal for the advice on Steele. I will call them on the seals. This Stovebolt is such a great place to get that hard to find information that the uninformed like me needs to get my sub back on the road. Thanks again guys. Weeds
#246819 03/26/2007 3:45 AM
Weeds, check out the swap meets that they attend, you may be able to get what you want from them there.
SWAP MEETS
Don't forget that there is a pretty good list of swap meets event calendars in the EVENTS section. Check out MARCH and APRIL
It looks like there may be one in your area coming up. You can take a sample and some pictures to them, maybe they can come up with something that will work.
July 12/13/14/15
Iola Old Car Show, Iola, WI
Krause Publishing Grounds
Spaces T-11 thru T-18 (near tower)
#246820 03/26/2007 11:44 PM
GMONIZ, Thanks for the swap meet suggestion. Its a good one. I will take the old seal with me to Spring Jefferson here in Wisconsin and see what I can come up with. Weeds
