3 members (NJC, Philipj, klhansen), 74 guests, and 4 robots.
Topics128,154
Posts1,056,842
Members48,456
#24619 12/02/2001 5:13 AM
Junior Member
Junior Member
hi guys,glad to find this forum.I have a 46 ton and a half with a bad tranny.It was formally used as log truck and after the brakes quit he used low gear as a brake till it shelled the teeth.I am planning to make it into a ramp truck to haul a model A **** racecar(also chevy six powered).Is there anything thats adaptable to the original bellhousing other than the trigger reverse that i now have?Also what else would yall recommend as to other modifications needed to haul a max load of 3000 pounds safely down the interstate at 65MPH or so. thanks in advance....(also forgot to say it already has a 261 swapped in).
#24620 12/02/2001 4:15 PM
Anonymous
Unregistered
Anonymous
Unregistered
Sounds like an interesting truck. You need to change your bellhousing to one from a 48-62. (Possibly even earlier than 48?) This will allow you to scrap that crashbox and install an SM420 4 speed with synchronized gears. Also, if you want to cruise anywhere close to 65 mph you'll have to do something about the gearing.
#24621 12/02/2001 4:52 PM
In addition to what Don said, you will need to fabricate a mounting plate for that late model bellhousing to mount your clutch/brake pedals on. Not too difficult but takes some measuring. Several members here have pictures that I'm they will be happy to send you. In addition the SM420 is a open driveshaft design.
Rick
46 1/2 ton Lucy
55 235, 52 bellhousing, 65 SM420, 77 driveline, 55 1/2 ton rearend all hooked together with a NAPA 348 u-joint. [img]http://community.webshots.com/scrip...photoID=25442874&security=DVrSWUFkJg[/img] wink
[ 12-02-2001: Message edited by: Rick Rickard ]
[img]http://wsphotofews.excite.com/009/X3/YY/Ys/9l12306.jpg[/img]
[img]http://wsphotofews.excite.com/020/cs/zh/eQ/9m61324.jpg[/img]
[ 12-02-2001: Message edited by: Rick Rickard ] http://community.webshots.com/scrip...photoID=25442910&security=alvGyFUDcI
[ 01-17-2002: Message edited by: Rick Rickard ][img]http://community.webshots.com/storage/1/v3/4/29/10/25442910alvGyFUDcI_ph.jpg[/img]
[ 01-18-2002: Message edited by: Rick Rickard ]
#24622 12/02/2001 10:22 PM
This set up in my some what stock 37 PU is not as engineered as Rick's, but has worked smoothly for 6 years.The clutch housing is from a 51 truck.I even managed to adapt the tranny mounted parking brake to a 56 Chevy car 3spd. [img]http://pstr-m04.ygpweb.aol.com/data/009/07/2C/D8/DC/2eUKajtBRd+f64ZA3-2y7OpSR7oM5k3B0180.jpg[/img]
#24623 12/03/2001 2:17 AM
Junior Member
Junior Member
thanks for the replies guys.i acually got the truck today and found out it is not a 261 like i was told...oh well...it was free anyway and pretty fixable.some has replaced the engine but it appears to just be a later type 235.i guess the 216 hauled one to many loads...thanks again guys
