1 members (HandyAndy),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24619 12/02/2001 5:13 AM | Joined: Dec 2001 Posts: 3 Junior Member | | Junior Member Joined: Dec 2001 Posts: 3 | hi guys,glad to find this forum.I have a 46 ton and a half with a bad tranny.It was formally used as log truck and after the brakes quit he used low gear as a brake till it shelled the teeth.I am planning to make it into a ramp truck to haul a model A **** racecar(also chevy six powered).Is there anything thats adaptable to the original bellhousing other than the trigger reverse that i now have?Also what else would yall recommend as to other modifications needed to haul a max load of 3000 pounds safely down the interstate at 65MPH or so. thanks in advance....(also forgot to say it already has a 261 swapped in). | | |
#24620 12/02/2001 4:15 PM | | Anonymous Unregistered | | Anonymous Unregistered | Sounds like an interesting truck. You need to change your bellhousing to one from a 48-62. (Possibly even earlier than 48?) This will allow you to scrap that crashbox and install an SM420 4 speed with synchronized gears. Also, if you want to cruise anywhere close to 65 mph you'll have to do something about the gearing. | | |
#24623 12/03/2001 2:17 AM | Joined: Dec 2001 Posts: 3 Junior Member | | Junior Member Joined: Dec 2001 Posts: 3 | thanks for the replies guys.i acually got the truck today and found out it is not a 261 like i was told...oh well...it was free anyway and pretty fixable.some has replaced the engine but it appears to just be a later type 235.i guess the 216 hauled one to many loads...thanks again guys | | |
