0 members (),
106
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi All, It's time to consider sound deadening and insulation for my 54 panel. I have read most of the info on this site but have specific questions with regard to panels. What can be done for the rear doors and those enclosed compartments forward and rear of the wheel wells? As always, Thanks.
All the best, Ted
| | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | hey ted i've been looking at a product at lowes that is an aluminum backed insulation. i have seen it used on air conditioning duct.it is 1/4" to 3/8" thick and has an o.k. r-value.you really need to put up some photos of that panel ,that, if i recall correctly "you drug out of the woods"  good luck. tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | stuff all your old grease rags in there and it will also help prevent rust  | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | On my roof I'm using owens Corning 703. It's what we use in recording studios to kill sound. You can find it at an insulation distributor but not at your nieghborhood lowes/home depot. Thios stuff is 1" or 1 1/2" thick and really does the job. | | | | | Joined: Jul 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 53 | You could try the spray on Lizard Skin. I'm considering it myself. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | how to: http://www.ehow.com/how_11208_sound-deaden-car.html there are several types of materials and costs involved here. what's right for your budget?? products avail: http://www.ehow.com/ehow_radlinks_a...7CCar%20Sound%20Deadening%7CRoad%20Noise b quiet is one http://www.b-quiet.com/ dynamat is the one that i have used along with the double sided aluminum insulation. http://www.dynamat.com/ note: the single or double sided aluminum composit material has a 1/4 - 5/16'' jute material type inner and is an insulation mostly type product. yes it does cut noise but these other two type products, dynamat and b quiet stick /adhear to the sheet metal and cut the vibration. using this type material, you do not have to completely cover the metal panel, maybe half, or sections as when you cover the roof. long 6'' strips work every 10-12'' apart. i put the jute material over the sound deadening stuff (cause it's very expensive).
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Thank you all so much... lots of good info with sites to look up and money to spend.
All the best, Ted
| | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | I used Lizard skin on my pick up project to stop heat from coming in and heat going out. I was totally amazed by the before/after results. It works. Atfer 2-3 coats, I used the Dynamat to stop vibes and noise from coming and going ( in/out). After that I used the aluminum faced felt to insulate and to offer some pad for carpeting. After all thius the cab is like a Caddy. It is overkill to most, but I planned this project as a total creature comfort machine. The aluminun mastic materielafrom HD/Lowes is called "Peel and Stick" and is used for heating/cooling sheet metal applications. It will stop some noise and vibration and some heat loss. It can be used in areas where there will be heat from sun,engine trans etc. The smell will dissipate in a few days. It is a great low cost alternative to the products. On the flooring you will still want the felt products over any of the other products. The Liz is 180.00 for 2 gallons and cleans up with water. It is similar to " Cool Car" I did a heat test on the Liz skin and burned my under cab paint waiting for the inside cab floor to heat up. More interesting parts to the story on request. | | |
