Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#24569 01/01/2005 5:43 PM
LT
Offline
Can stock exhaust manifold gaskets be used with headers? Engine is a 283 V8.
Thanks and Happy New Year!
LT
#24570 01/01/2005 6:44 PM
I would say no, use the ceramic one's. I've run some for the last 5 years without any problems,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#24571 01/01/2005 7:04 PM
LT
Offline
Thanks for the reply.
What's a ceramic gasket? How do you find them? What do you ask for?
This is my first experience with headers. They came on a truck I just bought.
LT
#24572 01/01/2005 11:01 PM
Just asks a parts house for a header gasket. It will be an off white color and feel kind of soft. The end bolt holes should be slotted so you can start the outside bolts with the header and slide the gasket down between the head and the header. After installing the gaskets and have driven it some, retorque the header bolts a few times until they won't tighten any more, then they will stay tight. Good luck,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
