4 members (MikeE, lc_btv, Oldcaliforniakid, Rexville48), 104 guests, and 3 robots.
Topics128,050
Posts1,055,673
#245557 05/17/2006 12:12 AM
looking for some help here. how big of a job is it to replace the floor, all thee panels and the toe. I have a 51 sub with only rust and paint left to do.running out time and money. hope this is something that I can do.
#245558 05/17/2006 2:42 AM
jm having replaced the entire floor on my 53 panel i dont thik it's too expensive(i guess that is relative) or too hard. a good spot weld cutter is well worth the money as it get the cuts done in a quick. a good welder is required to put it back together.brace everything and have fun. tom
I don't suffer from insanity, I enjoy every minute of it!
#245559 05/17/2006 1:06 PM
tom thanks for info. but what do you mean by brace everything ??
#245560 05/17/2006 11:44 PM
jm as yor remove the floor things might want to shift if not properly supported. if you remove the rockers ,floor sheetmetal ,ect at the same time the door pillars could not be in the same place when you start to put it all back.weldinging braces before you remove any metal will prevent the cab from settling out of place.check/search, i have seen some pics of some cab work somebody was doing in here.ask in the body/paint section they may have some pics they could direct you towards. tom
#245561 05/28/2006 2:00 AM
Ter Offline
Hi:
I just posted a question and it disappeared!!
My question was... what are you going to use for replacement panels for the floor? Are there reproduction panels out there? and if so are there any for the rockers too for subs. and panels?
Thanks and I'll try and click on the proper thing!!
Ter
#245562 05/29/2006 9:20 PM
JM I am not a welder or a bodyman by any stretch of the imagination but I stumbled through the replacement of my entire front floor and inner cowl panels plus part of the toeboard. All of the panels are available from most of the usual suppliers. No matter who you get the inner cowl panels from they won't fit very well. This was the only hard part of the whole thing. You can go to my site and see what I did to mine. Click on 'last uploads".
Weeds
#245563 06/01/2006 5:04 AM
weeds, like that name. Im finding out I don't have any other way to go but try to replace the floor my self. not one shop will touch it. thanks for the help. I may be back. Jack
#245564 06/01/2006 5:21 AM
Ter. well I think what Im going to for you is give you a list of parts catalogs to get you started. but Im not sure where I will go for my floor yet. still looking for a shop to do it for me. here is my list and thier are more. www.golden-statepartes.com www.lmctruck.com oldchevytrucks.com www.bowtiebits.com
