| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 16 New Guy | | New Guy Joined: Mar 2006 Posts: 16 | looking for some help here. how big of a job is it to replace the floor, all thee panels and the toe. I have a 51 sub with only rust and paint left to do.running out time and money. hope this is something that I can do. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | jm having replaced the entire floor on my 53 panel i dont thik it's too expensive(i guess that is relative) or too hard. a good spot weld cutter is well worth the money as it get the cuts done in a quick. a good welder is required to put it back together.brace everything and have fun. tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2006 Posts: 16 New Guy | | New Guy Joined: Mar 2006 Posts: 16 | tom thanks for info. but what do you mean by brace everything ?? | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | jm as yor remove the floor things might want to shift if not properly supported. if you remove the rockers ,floor sheetmetal ,ect at the same time the door pillars could not be in the same place when you start to put it all back.weldinging braces before you remove any metal will prevent the cab from settling out of place.check/search, i have seen some pics of some cab work somebody was doing in here.ask in the body/paint section they may have some pics they could direct you towards. tom
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hi: I just posted a question and it disappeared!! My question was... what are you going to use for replacement panels for the floor? Are there reproduction panels out there? and if so are there any for the rockers too for subs. and panels? Thanks and I'll try and click on the proper thing!! Ter | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | JM I am not a welder or a bodyman by any stretch of the imagination but I stumbled through the replacement of my entire front floor and inner cowl panels plus part of the toeboard. All of the panels are available from most of the usual suppliers. No matter who you get the inner cowl panels from they won't fit very well. This was the only hard part of the whole thing. You can go to my site and see what I did to mine. Click on 'last uploads".
Weeds | | | | | Joined: Mar 2006 Posts: 16 New Guy | | New Guy Joined: Mar 2006 Posts: 16 | weeds, like that name. Im finding out I don't have any other way to go but try to replace the floor my self. not one shop will touch it. thanks for the help. I may be back. Jack | | | | | Joined: Mar 2006 Posts: 16 New Guy | | New Guy Joined: Mar 2006 Posts: 16 | Ter. well I think what Im going to for you is give you a list of parts catalogs to get you started. but Im not sure where I will go for my floor yet. still looking for a shop to do it for me. here is my list and thier are more. www.golden-statepartes.com www.lmctruck.com oldchevytrucks.com www.bowtiebits.com | | |
