| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 22 Apprentice | | Apprentice Joined: Apr 2006 Posts: 22 | Hey guys,my 52 panel HAS a 6 in it. I know its not the orig. & I think its bigger than the orig. How do I tell what size [cu.in.] is in it now. Is there a code # on it somewhere or something? Thanks Jeff | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Get the casting numbers and look them up. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Jeff Go to the tech Tips space on this site and it has the information on how to find the casting numbers and identify the engine. Good luck and if you get stuck ping us again.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If it is a 216 original engine it will have a large side valve cover that goes up around the spark plugs and two bolts in the top valve cover.
If it is a 235 of later venue it will havce a short side valve cover about 8" tall and four side bolts on the top valve cover. This could also be a 261 engine with these features.
If it's neither of these then do the numbers as referenced by others. | | |
