2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#245479 04/16/2006 6:50 PM
Apprentice
Apprentice
Hey guys,my 52 panel HAS a 6 in it. I know its not the orig. & I think its bigger than the orig. How do I tell what size [cu.in.] is in it now. Is there a code # on it somewhere or something? Thanks Jeff
Get the casting numbers and look them up.
Jeff Go to the tech Tips space on this site and it has the information on how to find the casting numbers and identify the engine. Good luck and if you get stuck ping us again.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#245482 04/17/2006 10:55 PM
If it is a 216 original engine it will have a large side valve cover that goes up around the spark plugs and two bolts in the top valve cover.
If it is a 235 of later venue it will havce a short side valve cover about 8" tall and four side bolts on the top valve cover. This could also be a 261 engine with these features.
If it's neither of these then do the numbers as referenced by others.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
